daylight time saving ?
Login as swinst, go to expert menu, system management, Date & Time update, and set the timezone to
EST+5EDT;M4.1.0,M10.5.0
You are all done !
NB: Don't forget to set the good time after this, and note that the M are uppercase...
la_toupie
Post by la_toupie »
Of course, it depends on the place where you're !
in Europe and Maroc, put MET-01DST;M3.5.0,M10.5.0 !
Alejandro
Post by Alejandro »
What's the meaning of each parameter?
In Spain, Timezone is GMT+1 or GMT+2, changing last weekend of october and march.
TIA
Return to “Swinst”
