MULTISITE WITH OPERATOR PIMPHONY
selectt_DUP
Post by selectt_DUP »
What is the best way to impliment a remote site and use pimphony operator ?
Im installing site B with 8 H233 voip trunks and creating a VPN between both sites via ADSL.
I have tried to run the wizard to implement the main node and the reference node, the numbering scheme goes across but not all data. When i install pimphony operator on the main site A the remote users do not display on the screen only local users.
Does anyone have a correct procedure to impliment and bring in a new site onto a OXO network.
BlueFox
Re: MULTISITE WITH OPERATOR PIMPHONY
Post by BlueFox »
As far as I know, PIMphony will only operate in multi-site mode if you are using SIP instead of H323. Then you just ahve to add the IP address of site B's CPU to see all of their extensions
ACSE OpenTouch
ACSE OXE
ACSE OXO
ACSE 8770
ACFE CCSE
Return to “MAIN”
