CPU keeps restarting
faizullas
Post by faizullas »
hello...
has anyone have been having a problem whereby the system keeps rebooting...
please advise
torrentula
Re: CPU keeps restarting
Post by torrentula »
You might try giving some more detail, system release to start. I had an OXO that was rebooting randomly, an upgrade fixed the issue.
In this case you have to upload your CPU with LoLa .
Regards.
Oxosaysno
Post by Oxosaysno »
check the complementary info in the hardware/anomaly history. it will at least give you a point in the right direction as to whether it is hardware or software or even manual resets.
if software problem first thing is to Lola to highest patch release.
kosikidis
Post by kosikidis »
Maybe power supply??
http://www.kosikidis.gr
Krusty65
Post by Krusty65 »
Depending on the SW release there is an issue with R7.015.001 where the Albator process crashes.
Raise an e-SR and get the beta to fix it.
K
Return to “MAIN”
