Frequent reboot of OXO.
faizullas
Post by faizullas »
Hello.
I run an OXO 6.1 and is experiencing frequent boot issues. I have checked the ST chips as per TC0119 but instead of a 720, I have 736 chip.
Do you think this 736 chips is also a cause for this frequent reboot of the system ?? Or do you have any other idea??
Thanks you all.
aflores
Re: Frequent reboot of OXO.
Post by aflores »
Hello, have you made any modifications on the database or it is just rebooting since the firs time.
Wich version is?
Have you try to upgrade the systems to the lates version?.
Have you try to execute LOLA?
aflores
Post by aflores »
Another thing. We have some systems with Rel. 6.1 Version: 014.003 and CP3m and any of these systems have reboot never.
soenke
Post by soenke »
faizullas wrote:Hello.
Thanks you all.
I have the same problem with a oxo with r6.1.
alcatel says that the cpu is damage. next week i will swap the cpu and than we will see...
Return to “MAIN”
