Audio Station Upload to System
pcc2000
Post by pcc2000 »
I have compiled a Wav file with my audio station. Then i get a xyz.vpr and xyz.msk file wich is the bigger one. After that i have uploaded the xyz.msk file via FTP to /dhs3ext/vga/pc (also tried with /dhs3ext/vgadpcm/pc). Afterwards telnet to mtcl and call mgr. System -> Dynamic Voice Guides -> Import new files in database <Return> then i get a window with
header "import new files in DB" and Node Number=1,Instance=1,Instance=1. If i confirm with CTRL-V i get sucess displayed. Afterwards i clear import directory. But the file is not copied to the /dhs3ext/vg/dhs directory and so there is no dynamic voice guide to assign.
I have tried also to rename my wave file to 801_vg0801^ and copied directly to /dhs3ext/vg/dhs then the system recognises the file but i get as reason a "file not valid". So that easy way semms not to be possible i think there is an header missing in that normal wave file.
Please could someone help me ?
knightr1der
Re: Audio Station Upload to System
Post by knightr1der »
first - have you assigned the VG to a coupler?
Then, have you created the VG under Voice Guides?
no need to clean the import until you are happy its in and working.
pcc2000
Post by pcc2000 »
I have assigned the voice guide to the GD and also created the voice guide under Voice guides´. For me the problem seems to be the command "insert in Database" this seems not to work. Where should the xyz.msk file be located at the beginning on the CPU and what should happen after command "insert in Database".
If you do a downstat what do you see? also, what does incvisu says?
knightr1der
look in the folder on your PC where you have saved your project - you should see the wav file in there.
Try and rename it from EG:
802_vg802.wav
to
802_vg802 (and leave the ^) out of it.
Then try and copy (binary transfer) that to /usr7/vg/pc
then try your "import to database" option in mgr
pcc2000
Post by pcc2000 »
In the folder of my PC i have no xyz.wav file only a yxz.msk and xyz.vpr file. Is there something wrong i do with the audiostation (New Project, Edit Project -> Import wave file, Compile Project, Transfer Voice Guide).
knightr1der
maybe something wrong you are doing with aas.
Also, you must convert/make sure that the wav is 8 bit & 8 Khz mono A-Law format before even starting AAS.
Donnobo_DUP
Post by Donnobo_DUP »
Hey,
do u use FileZilla FTP-Client? Then try to change "Transfer-Type" to "Binary".
azhar
Post by azhar »
Its the version of your AAS software. You must be at least in R7.1to get the Dynamic messages option when you create the project.
hosshoss
Post by hosshoss »
I need the software of AAS
Return to “System”
