Look which ip adress is connected on working ports
Tuning4you
Post by Tuning4you »
I'm new with networking. We have an omniswitch 6850 and want an inventory of the network components connected to this switch.
With the commando show interfaces status i know which port is online.
With the commando show mac-address-table i know which mac address is connected on the ports.
For computers I can retrieve the ip by nbtstat - a <<mac-address>>. Some other components are medical apparatuses and this doesn't work.
Is it possible to know the ip addresses connected to the switch?
Kind regards,
Andy
benny
Re: Look which ip adress is connected on working ports
Post by benny »
You can try "show arp" but this will only work properly if the switch is routing for those boxes.
You could also use LLDP but I have some doubts if the medical equipment supports this kind of stuff already.
-benny
MWLosRios
Post by MWLosRios »
With 6.3.1, you can set up sflow to sample traffic on all ports and send it to a collector. Watch it long enough, and you should get a good idea of what systems are flowing traffic through that switch
sflow receiver 1 name collector address a.b.c.d
sflow sampler 1 port-range receiver 1 rate 512 sample-hdr-size 128
sflow poller 1 port-range receiver 1 interval 30
