the same alternativ Clip on several internal User
4400starter
Post by 4400starter »
Dear Experts,
One user an two multilines with different internal Numbers work´s.
My problem:
an internal IT-Hotline (1999) from my customer with 10 or more users.
all this user with different internal number want use the Hotline Number 1999 for outgoing internal dials...... i can not create a multiline with the same number on different sets. the hotline can be a virtuell set or any other set Outgoing external call´s can use "personal calling number".
Can you help me?
i hope this question was not posted in the past year
sorry for this bad english
JessicaS
Re: the same alternativ Clip on several internal User
Post by JessicaS »
You can create a virtual set with a PRIMARY key (1999) and the other set (user) you can program the same key but with different meaning with SECONDARY KEY
the name of this characteristic is MLA KEYS
Return to “Users”
