Alcatel SoftPanel Wallboard
knightr1der
I just installed this one.
It has a built in PC and comes with Ubuntu preloaded with firefox. It is configured to go straight into firefox once switched on. The URI obviously needs to be setup to point to the virtual wallboard you have set up in the WBM. Setting the IP address is the same as you do on traditional IP wallboards and when the Panel boots up, you will see the factory default IP @. Mine was 10.0.0.159
Re: Alcatel SoftPanel Wallboard
Nice! Is this for OTPE or only CCD?
Hehe, nice signature "list" however you missed the "Car washer ACSE Certified"
May be we should create a new forum named "Hall of fame" and put there photos of our numerous certificates?cavagnaro wrote:
knightr1der
The softpanel solution is for all 3 CC flavours;
- Standard
- Premium
- Genesys
My signature list should grow in december if I pass my University courses that I studied this year. Results due around 12th Dec
But if Successful, I will become: BSc (hons) Information and Communication Technologies
- Standard
- Premium
- Genesys
spinman
nice solution with the built in PC !
I just installed a softpanel as well, it's very nice and easy to configure! I used the agent status, but it is shown in 1.0, 5.0 and not status in text like "logged in", will have to something about that later...
We use a ordinary PC with a big screen to display with firefox.
You can change the logo, background and everything
But ProServ has made a nice layout so i will use it.
spinman
forgot to add..
theese agents are a beta-test for REX (business set) in PE group, it works really good, we have the same statuscontrol/realtimeinfo over a cellphone, like if they had a 4068 or something.
A very much requested function from our customers!
krzysioD
any documentation,
what license needed ?
how to order etc... ?
- frank
KnightRider,
I have a couple of wall boards in my lab, but I don t know how to use them.
What do I need to work with them ? Install a regular CCD ?
