4070 IO IBS DECT BASESTATION PROBLEM ONSITE
Everything about the PWT, IBS, RBS, DECT..
swinstu
Post by swinstu »
I have problem at a clients site where they have 13 IBS basestations running from a e-UA32 card. The whole card is programmed and used for Basestations leaving last 6 pairs 26 to 31 for 3 spare IBS stations ports for future use and testing purposes at pabx system tail.
I have 2 x basestations - 9 and 10 that do not work. Isolated with a new working Basetstation and still same thing. These used to work before and suddenly stopped working.
Issue with basestation number 9 is that it is INSERV for 5s and OUTSERV for about 15s. Red light flashes when in service and red light is solid. DECT sets lose and gain signal aswell. Tested a new basetstation and it works fine at the pabx system tail but does the same thing at basestation location which is about 200 meters away.
This basestation used to show 3 channels INSERV and after I checked the connections at location it changed to 6 channels and started acting in the inserv and outserv manner described above.
Results as below:
dectview ibs
Fri Dec 12 19:40:06 EST 2008
================= DECT RESOURCES BUSY STATE ===============
Resource Max busy free percent busy
Link 276 0 276 0.00
LCEI 300 0 300 0.00
ADPCM 0 0 0
Buffer UA-> 135 0 135 0.00
================= IBS States =======================
1/17/00 neqt 1407 RPN : 1 INSERV 6 channels DECT V 2G44.02 even IDENT NOR
MAL
1/17/02 neqt 1409 RPN : 2 INSERV 6 channels DECT V 2G44.02 even IDENT NOR
MAL
1/17/04 neqt 1411 RPN : 3 INSERV 6 channels DECT V 2G44.02 even IDENT NOR
MAL
1/17/06 neqt 1413 RPN : 4 INSERV 6 channels DECT V 2G44.02 even IDENT NOR
MAL
1/17/08 neqt 1415 RPN : 5 INSERV 6 channels DECT V 2G44.02 even IDENT NOR
MAL
1/17/10 neqt 1417 RPN : 6 INSERV 6 channels DECT V 2G44.02 even IDENT NOR
MAL
1/17/12 neqt 1419 RPN : 7 INSERV 6 channels DECT V 2G44.02 even IDENT NOR
MAL
1/17/14 neqt 1421 RPN : 8 INSERV 6 channels DECT V 2G44.02 even IDENT NOR
MAL
1/17/16 neqt 1423 RPN : 9 INSERV 6 channels DECT V 2G44.02 even IDENT NOR
MAL
1/17/18 neqt 1425 RPN : 10 OUTSERV (6 channels) DECT V 2G44.02 even IDENT NOR
MAL
1/17/20 neqt 1427 RPN : 11 INSERV 6 channels DECT V 2G44.02 even IDENT NOR
MAL
1/17/22 neqt 1429 RPN : 12 INSERV 6 channels DECT V 2G44.02 even IDENT NOR
MAL
1/17/24 neqt 1431 RPN : 13 INSERV 6 channels DECT V 2G44.02 even IDENT NOR
MAL
1/17/26 neqt 1433 RPN : 14 OUTSERV (6 channels) DECT V 2G 0.00 even IDENT NOR
MAL
1/17/28 neqt 1435 RPN : 15 OUTSERV (6 channels) DECT V 2G44.02 even IDENT NOR
MAL
1/17/30 neqt 1437 RPN : 16 OUTSERV (6 channels) DECT V 2G 0.00 even IDENT NOR
MAL
dectview ibs
Link 276 0 276 0.00
LCEI 300 0 300 0.00
ADPCM 0 0 0
MAL
MAL
MAL
MAL
MAL
MAL
MAL
MAL
1/17/16 neqt 1423 RPN : 9 OUTSERV (6 channels) DECT V 2G44.02 even IDENT NOR
MAL
MAL
MAL
MAL
MAL
MAL
MAL
MAL
The error/incident message recieved is as follows:
12/12/08 19:37:22 000004M|01/17/0/016|=3:3953=Internal IBS anomaly no 13, parame
ters 0 149 255 255
12/12/08 19:37:39 000004M|01/17/0/016|=5:3958=IBS operational
12/12/08 19:37:41 000004M|01/17/0/016|=3:3953=Internal IBS anomaly no 13, parame
ters 0 148 255 255
What could be wrong? Faulty cabling perhaps.
Issue with Basestation 10 is its dead which I believe is a cabling issue and will be looked at next time.
Any assistance/guidance to fix basestation 9 would be appreciated.
Thanks :D
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
Eliott_DUP
Re: 4070 IO IBS DECT BASESTATION PROBLEM ONSITE
Post by Eliott_DUP »
I know such incident's but can't remember the solution :?
01/03/06 18:30:08 000001M|01/14/0/022|=3:3953=Internal IBS anomaly no 13, parameters 0 150 255 255
01/03/06 18:30:17 000001M|01/14/0/022|=3:2050=UA Terminal 22 Loss
01/03/06 18:30:17 000001M|01/14/-/---|=4:3754=UA link no longer responding
01/03/06 18:34:55 000001M|01/14/0/022|=5:3958=IBS operational
I think it was a wiring problem.
My action plan suggestion is:
Change the IBS 8 against 9 and 9 against 8.
Same IBS has the problem?
Replace IBS.
Same UA-Port has the problem?
Cable, eUA32 Hardware or Software or ACT problem.
Replace eUA32 card.
Cable, or Software or ACT problem.
Connect IBS directly to ACT-Backplane.
Move eUA32 card to another ACT slot.
Software problem.
So you could try another IBS Firmware - I think the latest is 48.07
Is it a IOP Shelf?
Synchro okay?
infocs
dectinfo 3
dectview syncibs (let run some hours)
Maybe a trace can give an idea?
tuner km
trcterm n 1423
outserv n 1423
inserv n 1423
You could also try to manage UA sets on 1/17/16, 1/17/17, 1/17/18 and 1/17/19
Then try to connect and use them. Incoming call. Outgoing call.
(To prevent also wiring issues)
Did you tried to reboot the OXE?
No more ideas yet :)
swinstu
Post by swinstu »
Thanks heaps for your suggestion Elliot. I was able to fix the issue which was related to cabling in between the MDF - 2 x IDF and Basestation patch panel. Both up and running with 6 channels. Site had messy cabling. Good to learn some new commands just incase I stumble upon another IBS issue.
Regards.
SWINSTU
ACSE OXE R12.1
Return to “Wireless configuration and sets”
