Cant connect the MGR
lighningcrow
Post by lighningcrow »
Hi @all.
This is my first post in this forum.
Sorry about my bad english. But its a long time ago that i have used it.
And now my Problem.
I want to learn how to Configure a OXE and have installed an VM. (normaly i Configure OXO)
But i Cant start the mgr or menuselect.
I ever got an BIND error: BIND error panic: Can't initialize CMISE
Where is my fault???
Re: Cant connect the MGR
Please follow the tutorial posted in this same section.
lighningcrow
If you are meaning the slimphony tutorial -> I did it. Ive followed the complete tutorial.
ive load also the Rel. 6.0.
On both Releases (6 & 8 ) i got the same error.
Rel.6 installed as application server
Rel.8 installed as Blade server and Application Server.
If not, which tutorial should i Follow.
root
Post by root »
lighningcrow wrote:Hi @all.
And now my Problem.
Is tel running? Check with role, if answer is not MAIN type RUNTEL before
using mgr again
After software loading you need database - or loading from another PBX (f.e. for test), or create empty database (swinst/ expert menu/ database tool/ create empty database).
After this you can use mgr after tel application starting or without real start (f.e. after command RUNMAO).
lighningcrow
OK that´s was it. Ive created a new database and now i can go on.
Return to “Other”
