Cannot display Free Desktop on 4068 set
pretzellogic45
Yesterday I installed Free Desktop on a Windows 2003 SP1 server. According to the usual post installation checks the installation is correctly made. I added the OTUC server under XMLAPI connections and could see both of my PCX nodes in there. I wanted to have the "Free Desktop" appear on a key on the IP Touch 4068 sets, so I created the application in the presentation server of my OTUC server in this way - I named it FDEI and pointed it to http://135.222.8.72:8080/FreeDesktop/IP ... n/Register - I then restarted the presentation server service.
I then went to the PCX and under 8 & 9 series parameters I created the application as FDEI and Free Desktop. In class of service 0 (all phones are in this COS) I gave Free Desktop priority 14, which was the next available priority. My Phone and My Assistant are priority 12 and 13. However, Free Desktop does not appear in the display.
I do not understand how the keys are numbered. On the phone set My Phone is actually on key 9 and My Assistant on key 10. Surely the priority equals the key number ? I read in the documentation that Free Desktop should be alias 15 ? Does anyone know what that means ? Should it be priority 15 ?
Colin
Colin
Re: Cannot display Free Desktop on 4068 set
when you do in OXE an "appview -l" what is the status of your application?
pretzellogic45
Sorry, I meant to post that. I checked appview -s and I am connected to the presentation server. Here is the result of appview -l :-
Colin
Colin
Ok, it is clear that the application is not starting correctly. Can you open a browser and post the URL you configured in PRS and see if it returns a valid XML file? if it returns XML check your appserver logs and if it doesn't return the XML then check what is wrong with your webserver.
pretzellogic45
This is what came up on the page :-
type Status report
message /FreeDesktop/IPTouchIntegration/Register
description The requested resource
(/FreeDesktop/IPTouchIntegration/Register) is not available.
Apache Tomcat/5.0.28
type Status report
pretzellogic45
OK, this was a stupid mistake, but the URL was wrong. It should be http://135.222.8.72:8080/IPTouchInterface/Register
I had "integration" instead of "interface"
Colin
Colin
pretzellogic45
Actually no, when I checked the presentation server, I had entered it correctly, but when I entered the URL in my browser I put integration instead of interface. Now I get the XML page, but a guy from Pro Services tells me that port 2570 has to be open, so I will check that out.
<?xml version="1.0" encoding="UTF-8" ?>
- <body xmlns="http://www.alcatel.fr/IPT/v1.1">
- <register>
<url id="config"
value="http://135.222.8.72:8080/FreeDesktop/IP ... IPTFreeSea
tingManager" param="step=80&action=1" />
<prop id="rights" value="no" />
<prop id="key" value="open" />
<timer id="NotifyScanPeriod" value="1" />
<timer id="HTTPTimeout" value="150" />
<timer id="SessionInactivity" value="150" />
<http>POST</http>
</register>
</body>
- <register>
<url id="config"
<http>POST</http>
</register>
</body>
Can you post a screenshot on how you have configured the application link and options on WebAdmin?
