Hi guys,
I have a small issue in my lab..
Release: g1.503.21
Setup:
- 4059IP
- SIP trunk
- DPT1 trunk
- AudioCodes FXS112 with 2 analog phones
- X-LITE
- SIP phone
SIP phone calls the operator:
Operator seize a trunk, then transfer it to the SIP user
SIP user got the tone, and can dial out
X-Lite calls the operator:
Operator seize a trunk, then transfer it to the X-LITE user
X-LITE got a tone, but can't dial out (nothing in the traces)
Analog (audiocodes) calls the operator:
Operator seize a trunk, then transfer it to the Analog@Audiocodes
Analog receives fast busy tone.
I don't really care about the X-LITE (yet).. Is there anything to program on the Audiocodes in order to allow this kind of feature ?
Thx
Can transfer a trunk from the OP to analog behind audiocodes
- frank
root
Re: Can transfer a trunk from the OP to analog behind audiocodes
I think this is not working with SIP device, but maybe with SIP extension feature from R9.0?frank wrote:Hi guys,
Release: g1.503.21
Setup:
- 4059IP
- SIP trunk
- DPT1 trunk
- X-LITE
- SIP phone
Thx
- frank
Tried it already.
I think it's something on the Audiocodes box that needs to be configured.
I had it worked perfectly a couple of months ago and now that I need to do it again, i can't...
Did you look at SIP traces on the Audiocode?
Maybe a Codec issue... (with or without compression?)
hahaha didn't look at the date... You should have resolved your issue......
