GD reboot without warning
jerry
what does it mean below?
05/01/09 23:43:37 000001M|002/00/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot 16
05/01/09 23:43:59 000001M|002/00/-/---|=1:5856=MediaGateway has received a power supply alarm
GD did reboot without any warning, though, code(5857) says is GD has no enough buffer descriptor, but i still don't know how to solve this problem.
has anyone any idea? thanks.
those below is the complete content of log.
05/01/09 23:41:02 000001M|002/--/-/---|=2:2043=Loss of the 2 CRYSTAL
05/01/09 23:41:02 000001M|002/00/-/---|=2:2042=Loss of a GD type cpl
05/01/09 23:41:02 000001M|002/01/-/---|=2:2042=Loss of a GA type cpl
05/01/09 23:41:02 000001M|002/02/-/---|=2:2042=Loss of a Z type cpl
05/01/09 23:41:02 000001M|002/03/-/---|=2:2042=Loss of a Z type cpl
05/01/09 23:41:02 000001M|002/04/-/---|=2:2042=Loss of a Z type cpl
05/01/09 23:41:03 000001M|002/05/-/---|=2:2042=Loss of a Z type cpl
05/01/09 23:41:03 000001M|002/07/-/---|=2:2042=Loss of a Z type cpl
5/01/09 23:43:25 000001M|002/00/-/---|=4:0740=Beginning of an INT/IP downloading @:00.80.9f.82.00.30 (binmg)
05/01/09 23:43:25 000001M|002/00/-/---|=5:0741=End of downloading of an INT/IP board @:00.80.9f.82.00.30 (binmg)
05/01/09 23:43:48 000001M|002/00/-/---|=5:0409=The inter-ACT link over IP from (19 1) is up
05/01/09 23:43:48 000001M|002/00/-/---|=1:5856=MediaGateway has received a power supply alarm
05/01/09 23:43:49 000001M|002/00/-/---|=0:5857=GD/GA/INTIP/RGD: reason of reboot 16
Eliott_DUP
jerry
Re: GD reboot without warning
thanks again!
but sorry, I tried the step you give, it doesn't work!!(blue words below)
what's wrong with that?
Our OXE version is R8.0.1-g1.503-12-a
[root@eMGD log]# tar -czf logs.tgz
tar: Cowardly refusing to create an empty archive
Try `tar --help' for more information.
- tot3nkopf
Do you have GA on that shelf?
jerry
Yes! GA is on 2-1, the same shelf of GD.
Eliott_DUP
The * is missing - read the other thread carefully
You have to say what you want to save: * (all)
Eliott_DUP
tot3nkopf wrote:Do you have GA on that shelf?
jerry wrote:05/01/09 23:41:02 000001M|002/01/-/---|=2:2042=Loss of a GA type cpl
- tot3nkopf
To Elliot:
This happens when not paying attention.
To Jerry: Just use the command more with all the files in /var/log and capture screen, then post the text file here.
GA well configured? Other GA plugged in shelf without being configured? (anyway this is seen in logs so just post the logs as Eliott says)
jerry
I'v done the work with the file, infos.tgz & logs.tgz.
Eliott_DUP
Reset (reason memory problem : e-MGD Reset !
Page fault (errcode 0) at apa.o+0x11d21 (eip:c8c35d81 - eflags:10087)
I have no idea.
Is there an apa board?!
How often occurs the reboot?
Is the memory okay?
In my opinion we have two options left - try to replace hardware or try to upgrade software
