OXE Reboot Loop
talkhalidi
OXE Reboot Loop
Post by talkhalidi »
Hello all,
am facing an issue with OXE R8 which is in repeated reboot loop ,its not coming back at all, and if it tries to start from the hard disk it gives me message error on the file system.
i have attached the log for your reference
talkhalidi
Re: OXE Reboot Loop
also i want to add that , it always stuck in the monitor light menue
tch dog started
Monitor Light Menu
1 - Load From Hdisk #0
2 - Load From Ethernet
3 - Load From Flash NAND program
4 - Load From Flash NAND program and Bootp
5 - Load From Hdisk #0 and Bootp
6 - Display MAC address
7 - Display PCMS id
8 - Display System informations
9 - Full Options menu
10 - Switch console
11 - Reset System
?11F ðAlize BIOS Monitor
*** BIOS Version 3EH30227GLAA bios100/010.011 ***
*** Generated on Jun/15/2007 at 16:16 ***
talkhalidi
Re: OXE Reboot Loop
the default entry [0] will be booted automatically in 1 seconds.
Booting 'Boot GNU/Linux [default]'
root (hd0,4)
valeur index DXCX = FF01FEFF
kernel /boot/vmlinuz root=/dev/hda5 console=ttyS0,9600 panic=5
[Linux-bzImage, setup=0xa00, size=0x9b223]
Error 16: Inconsistent filesystem structure
Press any key to continue...
krzysioD
Re: OXE Reboot Loop
Post by krzysioD »
Well,
get a new disc and retry.
you try to install on a 60GB hdd in a Rack Server, try first to install on 20GB, i've never used such big hdd, maybe the RS bios is too old for that drive?
anyway, is your disc OK?
Error 16: Inconsistent filesystem structure -> means /dev/hda5 has a not clean linux filesystem and grub does not want to talk with it, use another drive and see results.
Re: OXE Reboot Loop
This problem exist from begining (after SW loading)?
talkhalidi
Re: OXE Reboot Loop
ok it always rebooting this way, is formatting the disk will fix the issue,?
talkhalidi
Re: OXE Reboot Loop
ITS KEEPING ON THIS LOOP BELOW, ANY IDEA
Hard Disk Detected
Hard Disk Found : 1
DMA enabled
PCM11 selected
Back Panel NMI disabled
Hard Drive APM supported and enabled -> Current Value is 0x80 ( not optimal )
WARNING !! Possible overload of Load Cycles Count in this Power Mode!!
Try to disable APM.
APM is now disabled.
CPU at 133 mhz
check lock RTC
value of DIL switch 1
YOU CAN strike Ctrl B to enter in BIOS monitor during several seconds from NOW
À ÝAlize BIOS Monitor
krzysioD
Re: OXE Reboot Loop
Post by krzysioD »
Go shopping mall,
buy good hdd,
reinstall,
then tell us how it went.
For me looks like broken hdd.
talkhalidi
Re: OXE Reboot Loop
Hello friends,
i have reloaded the software successuffly , created new data base , again when it restart it does not boot from the hardisk even i managed the HDD to be the first bootable device, i get the bios menu again. its really pissing me of.
there is crush dump on the hardisk , maybe this have impact on it. am not sure
travis1
Re: OXE Reboot Loop
Post by travis1 »
Go shopping mall,
buy good hdd,
reinstall,
If it was me i would
1. remove harddrive from CS.
2. Throw against wall and stamp on it repeatedly
3. now your harddrive is not attractive enough to re-use.
4. see KrysioD's quote above
have a nice day :-)
Return to “Software Loading”
