MOH not from oxo with GSM calls
SGE
Post by SGE »
Caller comes from GSM to oxo (test with o2 germany). Caller doesn't hear Moh from oxo. Only waiting message from GSM Provider (hold the line...) . Any ideas?
Re: MOH not from oxo with GSM calls
Not sure - but you can try - Debug Labels - FacilityIE change from 01 to 00.
When internal user make hold - PBX send to provider "FacilityMessage" about hold.
SGE
Post by SGE »
Thanks. I have changed FacilityIE change 00 and BC31k_ISDN 01. Than reset System.
problem remains...
please describe your case - GSM user dial number from OXO, OXO user answer and place call on hold and now external user hear announcement from GSM provider?
SGE
Post by SGE »
yes, GSM user dial number from OXO, OXO user answer and place call on hold and now external user hear announcement from GSM provider.
Try - Debug labels - NotifIndIE=0
SGE
Post by SGE »
wow! Thanks a lot vad. Great job, it works :D
Return to “MAIN”
