I am using alcatel version R7.1-f5.401-17-b-in-c0
My problem is i gets T2 Alrms on my PRI lines for 20 sec but no call drops
03/03/09 16:47:24 000000M|02/04/0/001|=4:2112=AIS alarm on T2 access
03/03/09 16:47:24 000000M|02/04/0/001|=2:0310=T2 Dlap Released
03/03/09 16:47:44 000000M|02/04/0/001|=5:2102=T2 access back to normal
03/03/09 16:47:44 000000M|02/04/0/001|=4:2113=T2 lapD not established still trying
03/03/09 16:47:44 000000M|02/04/0/001|=5:0311=T2 Dlap Established
AS in above logs also lines went down for 20 sec but none of the call dropped.
Can any body help me out on this
T2 Alarm on Alcatel for 20 Sec
tincho.rn
Re: T2 Alarm on Alcatel for 20 Sec
Hi. AIS alarm is related with the service provider. Regards.
sharma.birjesh
tincho.rn wrote:Hi. AIS alarm is related with the service provider. Regards.
NO I am sure that this problem is not because of S.P as I have more than 6 Alcatel 4400 at diff location and all of them facing the same problem after upgrading with the version 7
sharma.birjesh
I am sure problem is not becaause of S.P as i have tested the lines
torrentula
Have you checked your synchronization configuration? Use the infocs command to check it...
Gedeon
Check your board configuration (ie CRC4, or Trunk COS temps).
G.
G.
engineerishaque
Hello Sharma, is ur issue resolved? i am having the same problem with release 7 and the same incidents.
aho2009
Good morninig, I have a same problème with a release : 8.0 patch 27, can you give me the solution for this problem !!!
thanks
thanks
