hi all,
i want to install a AHL link over V24. the config done:
Review/Modify: Computer link─────────────────────────
Node Number (reserved) : 1
Instance (reserved) : 1
Interface Configuration + Standard
Port V24 + /dev/io2tty29 (43)
Overflow V24 + /dev/io2tty29 (43)
Transmission
All Cost CDR / Tickets + True
of Room CDR / Tickets + True
of Administrative CDR / Tickets + True
of Room Status Tickets + True
of Check-In - Check-Out + True
of Attendant CDR / Tickets + False
of Voice Mail Information + True
of Wake-up Information + True
of Suite Information + True
Extended ticket + False
No. Digits Guest Dir. + 5 digits
FIFO Size Alcatel Hotel Link + 500 Frames
Period for repeating message : 5
Prefix Filter : -----
Review/Modify: Data Terminal────────────────────────
Directory Number : 20299
Shelf Address : 0
Board Address : 17
Equipment Address : 3
Domain Identifier : 0
Specialization + None
Language ID : 1
Secret Code : ****
Confirm : ****
Public Network COS : 2
Charging COS + Justified
Connection COS ID : 0
Call Restriction COS : 0
Cost Center Id : 255
B Channel : 2
Data Group Dir. No. : --------
ISDN Teleservice + Non-standard Application
Adapter type + V110 + V120 Asynchronous
Terminal Type + VT100
Use + Set (No Emulation)
Setup Id : 10
Flow Control Id : 0
Output Config. Id : 10
Input Config.Id : 10
V120 No. : 0
Associated DATA station
External + True
Associated Set No. : 20290
V24 configuration
V24 Transparency + True
Off-hook By 108 + False
Off-hook By 105 + False
On-hook By 108 + False
On-hook By 105 + False
Observation time-out 108 + False
Observation time-out 105 + False
Observation 125 + False
Intervention 125 + False
Fast IO + False
Observation 108 + False
Observation 105 + False
Answer With 108 + False
Answer With 105 + False
Automatic Answer on UA set + False
Semi-permanent + True
Adaptation protocol + V120
Synchronous + Asynchronous
Cost Center Name : ----------
Modem Trunk Group Info
Trunk Group Id : 255
Trunk Number : 255
Incidents Teleservice + NO
Caller COS : 4
Secured Data + False
Implicit Priority
Activation mode : 0
Priority Level : 0
Review/Modify: Data Terminal──────────────────────────
Directory Number : 20298
Shelf Address : 0
Board Address : 17
Equipment Address : 14
Language ID : 1
Secret Code : ****
Confirm : ****
B Channel : 2
Setup Id : 10
Flow Control Id : 0
V120 No. : 0
External + True
Associated Set No. : 20291
V24 configuration
Fast IO + False
Trunk Number : 255
Caller COS : 4
Implicit Priority
Activation mode : 0
Priority Level : 0
Review/Modify: Data Application──────────────────
Directory No. : 20291
Directory Name : ----------------
Executable : /DHS3bin/servers/linf
Parameters : -D
Review/Modify: Data Application───────────────────────────────────
Directory No. : 20290
Executable : /DHS3bin/servers/hotmenu
Parameters : -l GEA
Review/Modify: TA adaptor────────────────────────
Shelf Address : 0
Board Address : 17
V24 Adapter + True
S0 Adapter + False
Z/UA Adapter + False
Remote TA adapter + False
my doubt is: how is the hotel computer link port /dev/io2tty29 (43) will talk to the TA adaptor? is there anything i have missed?
please let me know what you think the problem is?
i would much appreciate your inputs in the matter.
AHL link over v24
stekmtiki
obca
hi
the customer does not have obca daughter board. is that why i cannot connect using TA adaptor???
is it possible to use config cable and connect com B to the interface pc of fidelio?? in this case how do i program com B to be hotel frontoffice interface?
i would appreciate your inputs in the matter.
stekmtiki
hi
i am trying to connect to comC port of cpu for frontoffice computer(fidelio)
but when i program from system>v24ports, it is saying software protection error
what you think is the problem?
Consult/Modify: V24 Port──────────────────────────────
Port + /dev/scc0a (2)
V24 No. : 2
RTS/CTS protocol + False
Dynamic + False
TA Directory No. : --------
Speed + 9600 b/s
Parity + None
Data bits + 8 bits
Stop Bit + 1 Bit
Terminal Type + TTY
V24 Application + Hotel Front Office Computer
Parameters : ---------------------------------------
Port Dir.No (Static) : --------
V24 No. : 2
Dynamic + False
Speed + 9600 b/s
Parity + None
Data bits + 8 bits
Stop Bit + 1 Bit
Terminal Type + TTY
sundancekid1977
Regarding AHL over V24
the customer has got the license for AHL over IP but the version of fidelio the customer is using does not support IP. It only supports V24. Is it possible for me to connect the MOXA and give the V24 output to the customer? Is there any license required to cnnect the MOXA box as i dont get the option system---remote V24 configuration option under mgr.Please let me know how to go about it as this is very very urgent.
whistler_DUP
by the way, moxa box is the only solution for V24 AHL for OXE in case of "common hardware" because there is no free V24 port on CS, except console. moxa makes 4 additional V24 ports for applications like AHL and etc. Of cause you need no OBCA on CPU, moxa communicate with CPU frought special software drivers. I think it will work with crystal CPU as it works with CS. And it possible will be "low cost" way to make remote console, remote hotel menu, and remote V24 if we sum cost of TA, busy UA port, OBCA etc. My company install this kind of setup for hotel in OXE r5.1.2 and it works just fine several years
