which compressor daughter board?
alex
Post by alex »
Just learn how to see which compressor daughter board ACTUALLY connected to INTIP or GD/GA board.Now there is no need to unplug the board or use "cpl_online" command
config all -d
will show e.g.
   |  1 |  1 |       INTIPB(cpu mode) |   IN SERVICE |  3BA23193ABAD02 |
   |  1 |  1 |        One Board_GIP6A |   IN SERVICE |    NO PCMS CODE |
This works only on linux releases
sadim
Post by sadim »
You can use also "boardinfo"
Return to “Usefull commands”
