Call waiting Beep*(increase)
swinstation
Post by swinstation »
hi guys
how can I make an interval tone for call waiting beep instead of one beep(change to the interval beep like call waiting beep"s on cellphone)
travis1
Re: Call waiting Beep*(increase)
Post by travis1 »
Hey there,
The Call waiting beep is a tone - like any other in the system. Some are configuarable ..like this one.
It is tone 60. to alter it you simply adjust the values.
i.e To reduce the beep
Add a tone of “0” and adjust to length of 600 (6secs) and reduce the existing tone 23 down to “5”.
If you wanted to change the tone, just delete tone 23 and add another one that you like!
Hope that helps.
Trav
jpq4709
Post by jpq4709 »
I've done this for customers in the past. You must alter Tone 60 in combination with Timer 88. Here's how to do it:
Tone 60 (default value=Tone 25, Duration 50 ms/Tone 0 duration 50 ms) used for beep when second call arrives at set.
Timer 88 (default value=3) works in conjunction with tone 60. Works with 8 and 9 series sets. NOTE: Analog sets and monoline sets use different timer (?)
Key is to create tone 60 to same duration as timer 88 and yet not exceed value of timer 4 used for overflow on no answer otherwise the call waiting tone will continue to beep even after the call has forwarded to the associated set.
Tone 60
1. Tone 25 (BEEP) duration 200
2. Tone 0 duration 300
3. Tone 25 duration 200
4. Tone 0 duration 300
Timer 88=100
Hope this helps!
swinstation
hi there
i did it and thank everybody that helped me.
Return to “System”
