Upgrade from R.2.x to R.7
klodjan bregu
Post by klodjan bregu »
In our office we have an OXO R2.x (CPUe-1,CoCPU-1) e-bussines.
Even it has these internet features we dont use them at all because we are using an ECS.
We want to upgrade it to the lasted release, but i never done such a thing before.
What I'm asking is what I have to do excactly to do all this.
Do I have to order another CPU or only some spare parts or any specific licence?
I have no idea how it works.
Any suggestion will be helpful.
Klodjan
mavijitr_DUP
Re: Upgrade from R.2.x to R.7
Post by mavijitr_DUP »
Find herewith the R7.0 limits and dimensioning document.
In your case, the CPUe-1 is supported based on this docuemnt. You require a license to upgrade your system to R7.0
At first, you have to go to last R2.x patch version, I think it is 93.001 and then migrate to R7.0.
Update the site for your further quries.
Vijay
mavijitr_DUP
The exact steps given in the technical communication TC1053.pdf. I attach herewith for your references. This document will help you for the migration.
Vijay
When you quote Actis telles you what to do for upgrade (usually ads a hard disk).
Regards.
Return to “MAIN”
