Help me to fix crystal system for incoming call
doublevand981
Post by doublevand981 »
Dear sir
My system is crytal, CPU7, R8.0.
i am using Charging NDDI (BCA) trunks for incoming call. But i got big problem that:
the outside caller call to my system. ring to operator. the operator not answer. then caller hang up. the operator phone still ringing till he press release. if he did not press release the phone ring for long time.
pls help me to fix this
thank
doublevand981
YM; doublevand981@yahoo.com
skype: vankv2000
Cell: 84-912 562 263
Re: Help me to fix crystal system for incoming call
Check the polarity reversion configuration, sounds to me like OXE is not detecting the hangup event. Check if your lines have this facility.
doublevand981
Pls guide me detail how to config polarity reversion.
how to check it in my system
Read the documentation, follow red banner, examples and detailed guide are provided
If we have incoming NDDI calls (not answered) - end of incoming calls - just stop incoming ringing.
But in this case we say about operator - may be used incoming greeting or something else?
swinstation
Post by swinstation »
hi there
how are you?
i have your problem too and solved it with this configuration:
system---tone detector parameter---busy tone--play with the minimum and maximum (digit) and i hope that you can fix it.
minimum pulse timer(busy tone)=40(default)
maximum pulse timer(busy tone)=60(default)
change the digits for example minimum=30 maximum=40
it is necessary to mention, your both minimum digit should be like together and maximum too and please pay attention if you reduce the digit may be your line cut off between conversation.try and let me know the result.
email:masoud.nouri@nuranetworks.com
swinstation
i am sorry
system--tone detector---on hook tone------- change them
doublevand981
hi all,
i fixed this problem with crystal OXE by adjust system other parameter:
No detect.of On-hook tone + False
but with Common HW OXE problem still there Even i changed parameter as above for this.
any one can help me??
Compare in both systems parameters (like was written before) - system/tone detector - on hook tone
doublevand981
hi sir,
you mean i adjust system/tone detector - on hook tone
minimum to 30
maximu to 40
right?
Return to “Usefull commands”
