How to configure DHCP relay??
akagi
Post by akagi »
Hye all..
I want to configure dhcp relay. Anyone please advice me to explain to cofigure dhcp relay correctly by step. Because before that i folloow the manual, my configuration still not fucntion. Hope you all can help me k.
Thanks...
benny
Re: How to configure DHCP relay??
Post by benny »
! UDP Relay :
ip helper per-vlan only
ip helper address 192.168.10.100 vlan 11
You might want to configure a forwarding delay of 0 in some cases.
-benny
akagi
Post by akagi »
hye..
DHCP relay related with SNMP right??
So i should configure SNMP first??
Thanks.
No, you don't need any snmp-config for dhcp-relais (= ip-helper).
Try the commands benny has givven you.
