Hello. I have a problem with corrupted database. Have anyone any answers?
I tried to rebuild it with: RUN: c:/nmc/bin/rt32w -d c:/nmc/bin/ac5base.db, but it's not working. Any suggestions?
really need help
4740 problems
mavijitr_DUP
Re: 4740 problems
do you have any backups? 4760 backup?
pls update with release and version of your software..
Re: 4740 problems
Check the subject. It is about 4740 which has been phased out ages ago and not supported almost for a decade.mavijitr wrote: pls update with release and version of your software..
Re: 4740 problems
You can have problem with database if file very big (what size of db file and which file system used on your PC - FAT32, NTFS?)
And what about free space on your HDD (for working with DB you need free space 2,5xDB_size).
mavijitr_DUP
Re: 4740 problems
Alex,
I asked him to provide the release and version of the software for more clarity..
Vijay
Vijay
andrej klavzar
Re: 4740 problems
The problem was solved. New installation and older backup. that was all that helped.
Thanx anyway.
Thanx anyway.
- tot3nkopf
Re: 4740 problems
That was always the solution for 4740 db corruption (or at least the only one that I know - this happenned quiet often as I remember).andrej klavzar wrote:The problem was solved. New installation and older backup. that was all that helped.
Thanx anyway.
Pooja Ramchurn
Re: 4740 problems
Hi, I have the same issue.
Is there any tool that can be used to read that data? The data is 2Gb. We need the information for accounting purposes.
And please advise on the steps for new installation.
Thanks,
Pooja
Thanks,
Pooja
