Integration PBX OXO to PBX Panasonic D232
fiendish999
Post by fiendish999 »
Hi Experts,
Good Day!!!
I need your help. this is very complicated. please reffer to the attachment and please tell me your opinion about the diagram...
Thanks in advance!!!
Re: Integration PBX OXO to PBX Panasonic D232
Your diagram is incomplete. How are the 2 PBX interconnected: ISDN, analog or IP lines? Where are the public lines connected: OXO or Panasonic? What are you trying to achieve with this?
fiendish999
Re: Integration PBX OXO to PBX Panasonic D1232
there is a single lines drawn from phones to the 2 PBX it is the indication where it is connected. there are no digital phones just analog phones. the question is where do we connectec the PSTN it should be at the OXO or at the panasonic? Second question is the analog phones are connected to the panasonic, how to configure the analog phones to the OXO?
The phones are connected to both PBX's?
I don't understand what you need and how are your PBX's connected to each other. Wouldn't it be easier to use only one?
fiendish999
hello Sir tot3nkopf,
Good Day!!!
I don't have a choice that what our client wants. About the connection from analog phones connected to the panasonic pbx and the panasonic pbx is connected to the OXO from the OXO it is connected to the router.
Questions:
1.) Where do i connect the PSTN? Is it on the OXO or on the panasonic pbx?
2.) from that setup, the analog phones are connected to the panasonic pbx, question is, how do we configure it to the OXO?
fiendish999
any one have an idea? Please feel free to reply!!
Thanks..
Try to be more specific about the connection between Panasonic and OXO.
Chun725
Re: Integration PBX OXO to PBX Panasonic NS300
Post by Chun725 »
Hi Experts,
Good Day!!!
I need your help. How to setup OXO to Panasonic NS300 using SIP trunk Link ?
Return to “Configuration”
