automatic bascul
gundam
automatic bascul
Post by gundam »
Anyone here have a script to automaticlly bacscul the 4400 every month?
maybe a cron
But for what reason? Automatic bascul will be automatic. Network links, DECT network will be restarted (out of services during some time).
Maybe he is trying to clean memory in order to prevent some failure
alex
Re: automatic bascul
Post by alex »
It is not a big problem to develop such a script.It will take just few lines.
Main point to observe - it should be the same on both CPUs.
It should check whether CPU is main, whether all applicatons compatible and whether AUTOSTART is enabled on both CPUs.
It should place "shutdown -r 0" into cron table.
Place it in rc.d directory, name it accordingly.
Add a script in /etc/cron.monthly
!#/bin/bash
/bin/echo y | /usr2/oneshot/mtcl/tool hotbascul
this will reboot the pbx everymonth without checking if the 2nd cpu if up and running.
Return to “GENERAL”
