-> copy working certified
ERROR: Insufficient Flash Space, Can Not Perform Action
CERTIFY process failed
ERROR: Attempt to copy working to certified failed
Best regards
-> ls -r
Listing Directory /flash:
-rw 334 May 25 10:06 boot.params
drw 512 May 15 18:30 certified/
drw 512 May 25 08:05 working/
-rw 11 Jan 4 2004 boot.slot.cfg
-rw 64000 May 25 11:21 swlog1.log
-rw 256 Apr 7 2008 random-seed
drw 512 May 23 17:39 network/
-rw 3258994 Apr 7 2008 cs_system.pmd
-rw 64000 May 23 17:37 swlog2.log
drw 512 Feb 1 2004 switch/
Listing Directory /flash/certified:
drw 512 May 15 18:30 ./
drw 512 May 25 10:06 ../
-rw 105613 Dec 29 2003 certs.pem
Listing Directory /flash/working:
drw 512 May 25 08:05 ./
-rw 485357 May 23 17:26 Hadvrout.img
-rw 4100715 May 23 17:28 Hbase.img
-rw 114588 May 23 17:28 Hdiag.img
-rw 1513810 May 23 17:28 Heni.img
-rw 920941 May 23 17:29 Hl2eth.img
-rw 1090564 May 23 17:29 Hos.img
-rw 245961 May 23 17:29 Hqos.img
-rw 5088 May 23 17:30 Hrelease.img
-rw 605105 May 23 17:30 Hrout.img
-rw 130184 May 23 17:30 Hsecu.img
-rw 1509191 May 23 17:30 Hweb.img
-rw 315566 May 23 17:31 Hwebl2eth.img
-rw 130715 May 23 17:30 Hwebadvrout.img
-rw 263442 May 23 17:31 Hwebqos.img
-rw 269715 May 23 17:31 Hwebrout.img
-rw 219946 May 23 17:31 Hwebsecu.img
-rw 3097 May 25 08:05 boot.cfg
-rw 264288 May 23 17:32 bootrom.bin
-rw 591470 May 23 17:32 miniboot.default
-rw 1130 May 23 17:33 software.lsm
-rw 591470 May 23 17:33 miniboot.backup
Listing Directory /flash/network:
drw 512 May 23 17:39 ./
-rw 32 Oct 16 2002 policy.cfg
-rw 19968 Apr 28 10:51 userTable
-rw 404 Jun 11 2003 ssh_host_dsa_key
-rw 360 Jun 11 2003 ssh_host_dsa_key.pub
-rw 22016 May 23 17:39 userTable3
Listing Directory /flash/switch:
drw 512 Feb 1 2004 ./
drw 512 Feb 1 2004 avlan/
-rw 1504 Feb 1 2004 label.txt
-rw 944 Feb 1 2004 wv-cert.pem
-rw 981 Feb 1 2004 wv-key.pem
-rw 20 May 23 17:52 snmp.engine
-rw 0 Feb 1 2004 pre_banner.txt
Listing Directory /flash/switch/avlan:
drw 512 Feb 1 2004 ../
-rw 445 Feb 1 2004 topA.html
-rw 358 Feb 1 2004 topB.html
-rw 388 Feb 1 2004 bottomA.html
-rw 384 Feb 1 2004 bottomB.html
-rw 8215 Feb 1 2004 javlan.cab
-rw 12457 Feb 1 2004 javlan.jar
-rw 1120 Feb 1 2004 avlanMacInstall.html
-rw 51200 Feb 1 2004 avlaninstall.tar
-rw 12090 Feb 1 2004 javlan.jar.sig
-rw 5327 Feb 1 2004 javlaninstall.sit
-rw 11034 Feb 1 2004 javlanmacosx.jar
-rw 1473 Feb 1 2004 reconfigApple.html
12593152 bytes free
ERROR: Attempt to copy working to certified failedCERTIFY requested while running the certified version of SWCode: Select all
->ls -r
?-- 0 Jan 1 1970 B~99999?.PAR
?-- 0 Jan 1 1970 boot.slo|.cfg
?-- 0 Jan 1 1970 log1.log
?-- 0 Jan 1 1970 log2.log
drw 512 Jun 29 2006 SWITCH/
?-- 0 Jan 1 1970 C~99998?
drw 512 Apr 11 12:19 _ORKING/
?-- 0 Jan 1 1970 NE\WORK
?-- 0 Jan 1 1970 PRO^A1
?-- 0 Jan 1 1970 T~9999?>.LOG
?-- 0 Jan 1 1970 T~9999?3.LOG
?-- 0 Jan 1 1970 T~9999?0.LOG
?-- 0 Jan 1 1970 T~9999>?.LOG
-rw 65024 Jan 30 23:48 S_LOG2.LOG
-rw 65024 Jan 31 00:30 S_LOG1.LOG
Listing Directory /flash/SWITCH:
drw 512 Jun 29 2006 ./
drw 512 May 25 12:36 ../
?-- 0 Jan 1 1970 .b9ccbQcQe9.|xt
-rw 20 Mar 30 07:59 snmp.engine
-rw 0 Mar 29 2006 pre_banner.txt
?-- 0 Jan 1 1970 A^LAN
-rw 1732 Jun 21 2006 label.txt
?-- 0 Jan 1 1970 _^-CERT.PEM
?-- 0 Jan 1 1970 ========.=!
?-- 0 Jan 1 1970 g/boot.c.fg
?-- 0 Jan 1 1970 ugores
s.yst
?-- 0 Jan 1 1970 em locat.ion
?-- 0 Jan 1 1970 name "S.onT
?-- 0 Jan 1 1970 router i.p 1
?-- 0 Jan 1 1970 an 228 p.ort
?-- 0 Jan 1 1970 t 1/6
vl.an
?-- 0 Jan 1 1970 vlan 228. po
?-- 0 Jan 1 1970 28 port.def
?-- 0 Jan 1 1970 rt defau.lt
?-- 0 Jan 1 1970 fault 1/.12
?-- 0 Jan 1 1970 1/13
vl.an
?-- 0 Jan 1 1970 228 por.t d
?-- 0 Jan 1 1970 port def.aul
?-- 0 Jan 1 1970 default.1/2
?-- 0 Jan 1 1970 22
vlan.228
?-- 0 Jan 1 1970 8 port d.efa
?-- 0 Jan 1 1970 able nam.e "
?-- 0 Jan 1 1970 xim"
vla.n 1
?-- 0 Jan 1 1970 1020 rou.ter
?-- 0 Jan 1 1970 255.255..248
?-- 0 Jan 1 1970 e "Enlac.e_O
?-- 0 Jan 1 1970 n 1030 s.tp
?-- 0 Jan 1 1970 ter ip 1.72.
?-- 0 Jan 1 1970 .248 e2.
vl
?-- 0 Jan 1 1970 1/19
vla.n 1
?-- 0 Jan 1 1970 ce_OSPF_.ST_
?-- 0 Jan 1 1970 p 172.28..13
?-- 0 Jan 1 1970 e2
vlan. 10
?-- 0 Jan 1 1970 oseta"
v.lan
?-- 0 Jan 1 1970 8.135.74. 25
?-- 0 Jan 1 1970 n 1070 p.ort
?-- 0 Jan 1 1970 L:
! IP.:
i
?-- 0 Jan 1 1970 :
! AAA.:
a
?-- 0 Jan 1 1970 ault "lo.cal
?-- 0 Jan 1 1970 size min. 1
?-- 0 Jan 1 1970 802.1x.:
?-- 0 Jan 1 1970 banner.cli
?-- 0 Jan 1 1970 anner ft.p b
?-- 0 Jan 1 1970 600
sess.ion
?-- 0 Jan 1 1970 ion prom.pt
?-- 0 Jan 1 1970 " user ".snm
?-- 0 Jan 1 1970 manager.:
i
?-- 0 Jan 1 1970 0.0.1
ip. st
?-- 0 Jan 1 1970 sk 0.0.0..0
?-- 0 Jan 1 1970 tric 1
i.p s
?-- 0 Jan 1 1970 6.0 mask. 25
?-- 0 Jan 1 1970 72.28.10..11
?-- 0 Jan 1 1970 255.0 ga.tew
?-- 0 Jan 1 1970 ic 1
ip.sta
?-- 0 Jan 1 1970 2.28.10..110
?-- 0 Jan 1 1970 255.248.gat
!. RI
?-- 0 Jan 1 1970 ospf
ip.osp
?-- 0 Jan 1 1970
ip os.pf
?-- 0 Jan 1 1970 status.ena
?-- 0 Jan 1 1970 0.1
?-- 0 Jan 1 1970 vlan 130. ro
?-- 0 Jan 1 1970 e name ".ST_
vla.n 1
?-- 0 Jan 1 1970 31.1 255..25
?-- 0 Jan 1 1970 enable n.ame
?-- 0 Jan 1 1970 132 stp. di
?-- 0 Jan 1 1970 ip 172..28.
?-- 0 Jan 1 1970 e2
vlan.133
?-- 0 Jan 1 1970 n 133 ro.ute
?-- 0 Jan 1 1970 .255.255..0
?-- 0 Jan 1 1970 ame "ST_.res
?-- 0 Jan 1 1970 disable.
vl
?-- 0 Jan 1 1970 28.134.1. 25
?-- 0 Jan 1 1970 vlan 136. st
?-- 0 Jan 1 1970 .0 e2
v.lan
?-- 0 Jan 1 1970 255.255..25
?-- 0 Jan 1 1970 stp dis.abl
?-- 0 Jan 1 1970 172.28.1.38.
?-- 0 Jan 1 1970 lan 139.ena
?-- 0 Jan 1 1970 9 router. ip
?-- 0 Jan 1 1970 .255.0.e2
?-- 0 Jan 1 1970 "ST_rese.rva
vla.n 1
?-- 0 Jan 1 1970 40.1 255..25
?-- 0 Jan 1 1970 141 stp. di
?-- 0 Jan 1 1970 e2
vlan.142
?-- 0 Jan 1 1970 n 142 ro.ute
vl
?-- 0 Jan 1 1970 28.143.1. 25
?-- 0 Jan 1 1970 4 255.25.5.1
?-- 0 Jan 1 1970 3
vlan 2.28
Listing Directory /flash/_ORKING:
drw 512 Apr 11 12:19 ./
-rw 3686463 Jun 21 2010 Hbase.img
-rw 114460 Jun 29 2010 Hdiag.img
-rw 1908258 Jun 21 2010 HENI.IMG
-rw 831756 Jun 29 2010 Hl2eth.img
-rw 896766 Jun 21 2010 Hos.img
-rw 296292 Jun 21 2010 Hqos.img
-rw 524353 Jun 29 2010 Hrout.img
-rw 1344798 Jun 21 2010 H_EB.IMG
?-- 0 Jan 1 1970 H~9999?9.IMG
-rw 247392 Jun 21 2010 H_EBQOS.IMG
-rw 159006 Jun 21 2006 H_EBROUT.IMG
-rw 7717 Jun 21 2010 Hrelease.img
-rw 105485 Jan 25 2005 certs.pem
-rw 6631 Dec 15 2010 boot.cfg
?-- 0 Jan 1 1970 HAD^ROUT.IMG
-rw 129326 Jun 21 2006 Hsecu.img
?-- 0 Jan 1 1970 H~9999>2.IMG
-rw 212964 Jun 21 2006 H_EBSECU.IMG
-1 bytes free
