DTMF during a conference call
morry70
Post by morry70 »
Hi all,
i'm having trouble on the use of DTMF during a conference call
i try to explain :
during an incoming call i need to connect ( conference) with an external service for call recording and it asks to dial a pin for logging in .
After placed the first call on hold, i make a second external call to the recorder system and at the answer i press the dtmf key on my phone and i dial the pin code . After this step i should press the conference key and put all toghether in conference, but the system didn't send any tone on the call to the recorder so i can't login, start rec and complete the call.
I'm on an OXO rel. 410/015 and using an UA interface (tested on First and Premium Phone)
Thanks in advance for any suggestion
Zoltar13
Re: DTMF during a conference call
Post by Zoltar13 »
Should you have to press the DTMF key on an outgoing call?
morry70
Post by morry70 »
Thank's all,
Solved
laoade firmware again with lola and the everithing works great
I must press dtmf key every time i do a new action (example : after 2 call and after pressed conference key)
the tone are transmitted only on the second call ( the first caller in/out the same, doesn't hear nothing)
Return to “MAIN”
