OMC Login Problem:
samehit
OMC Login Problem:
Post by samehit »
Hi All
I have omniPCX OXO with CPU-3m from Alcatel only (not Alcatel-Lucent).
OXO IP is : 192.168.92.246 (I know OXO IP using ping command)
So when I try to enter to the OXO by OMC program
I enter Password :**************
But connection fail and error message appear :
(HTTPS (login4) soap login error . error code no connection could be made because the target machine actively refused it) .
Please if any one know any information about this problem please tell me
Thanks & Beast Regard
Reason: No password allow
d-mgr
Re: OMC Login Problem:
Post by d-mgr »
What version OXO are you running and what OMC version?
your OMC and OXO versions must match in most cases. If you have an older OXO you then must use PM5.
samehit
Post by samehit »
d-mgr wrote:What version OXO are you running and what OMC version?
Thank Sir
I don't know the version of OXO Operation System, and I used OMC R7.
Remake when I attached digital phone on UA interface, the phone don't appear any response (phone don't work).
d-mgr
Post by d-mgr »
Is this a new install?
you should try different versions of OMC until you connect or maybe PM5.
samehit
Post by samehit »
thank sir
can you tell me version number of OMC that work corectly
with OXO (with CPU-3m)
please help me to solve this problem
thank & beast regard
d-mgr
Post by d-mgr »
try OMC v5,6,and 7 and PM5
No way to tell OXO version so try each one until connected. good luck
petepsg
Post by petepsg »
that looks like the error message you get when the password is wrong..
try connecting with an admin version of omc (rename expert.dll) and see if that works. if you can connect with that then you don't have the correct password.
also you can read what software release is on the system if you can connect then.
Return to “Configuration”
