G711 and 4645
florent
G711 and 4645
Post by florent »
Hi all !
I have a 4645 integrated with the call server.
All my IP Phones work well on the LAN to access the 4645 but not the IP Phones on other sites through the WAN.
The communications between IP Phones and between IP Phones and MG are in G729 but the 4645 only works with G711.
It's why it doesn't works.
How to use compression for the 4645 ?
Florent
alex
Re: G711 and 4645
Post by alex »
It should work if you correctly set up IP domains.
http://alcatelunleashed.com/viewtopic.php?f=13&t=7155
Return to “Voicemail (46x5)”
