zmodem transfert pb
fykloo
zmodem transfert pb
Post by fykloo »
Hi all,
i made a mistake when i wanted to change the AOS version of my switch.
I copied bad image files in working and certified folder :?
So i tried to follow this procedure:http://alcatelunleashed.com/viewtopic.p ... rt*#p30384
But when i want to send a file, i had an error: "No connection with the remote system" (translation from french to english, i don't know if it's the right message)
For information : I use Hyperterminal v5.1
I tested zmodem transfert between 2 computers and it works.
If you have any idea ...
benny
Re: zmodem transfert pb
Post by benny »
I never used HyperTerminal for that. I suggest you get SecureCRT or TeraTerm (http://ttssh2.sourceforge.jp/).
The procedure is confirmed to work.
-benny
fykloo
Post by fykloo »
I have the same problem with TeraTerm.
In fact i don't follow exactly this procedure because i don't have a couter decreasing.
So i changed the baudrate and the flag using:
[Miniboot]->bootChange
I don'k use this command because i don't know if it is useful :
bootm 0xff900000
Then the working and certified folders are already created and they contain *.img files, boot.cfg and certs.pem files.
So i made a cd "certified" and at this moment
[Miniboot]->sysStartZmodem
It displays this message :
Upload directory: /flash/certified
rz ready to receive file, please start upload (or send 5 CTRL-X's to abort).
**B0100000023be50
Then File->Transfert->Zmodem->Send...
I choose my img file but the upload never starts :(
I already tried to delete all img files in my folders.
fykloo
benny
Post by benny »
The "bootm + 0x memory address" command is a uboot command to go to the Miniboot. As you are already in the Miniboot you can skip that step. If you have no counter decreasing you are running a very old chassis where the "interrupt boot"-jumper wasn't set per default. Anyway - we don't need that as you go to the Miniboot already.
Did the console-speed actually change after you "tried"? You should set it to 115200 on switch & teraterm and reboot to miniboot again.
Now you delete the *.img files from the certified folder and use the zModem command to upload the images.
I don't have a OS6600 right now but I tried it at that time ...
Here is another topic which might help: http://alcatelunleashed.com/viewtopic.php?f=137&t=5763
-benny
fykloo
Post by fykloo »
i don't know why but as you said i had to delete all files in my certified directory
then the copy was fine
and know my switch works perfectly :)
ty benny for your time
