HI
I have a problem with configuring the NTP setings on the 6850,6400 and 9700 swithces.
I have configured the following on teh swith.
F2-B-1-> show configuration snapshot ntp
! NTP :
ntp server 172.17.1.12 key 0 version 2 minpoll 4 prefer
ntp broadcast enable
ntp broadcast-delay 10
ntp client enable
The folling info i get fram the show command.
F2-B-1-> show ntp server status
IP address = 172.17.1.12,
Host mode = client,
Peer mode = server,
Prefer = yes,
Version = 2,
Key = 0,
Stratum = 3,
Minpoll = 4 (16 seconds),
Maxpoll = 10 (1024 seconds),
Delay = 0.016 seconds,
Offset = 0.766 seconds,
Dispersion = 0.468 seconds
Root distance = 0.190,
Precision = -6,
Reference IP = 172.17.1.1,
Status = configured : reachable : synchronization peer,
Uptime count = 13173186 seconds,
Reachability = 1f,
Unreachable count = 0,
Stats reset count = 13173099 seconds,
Packets sent = 5,
Packets received = 5,
Duplicate packets = 0,
Bogus origin = 0,
Bad authentication = 0,
Bad dispersion = 0,
Last Event = peer changed to reachable,
F2-B-1-> show ntp client
Current time: Thu, Aug 20 2009 10:00:14.500 (UTC),
Last NTP update: Thu, Aug 20 2009 10:00:07.750 (UTC),
Server reference: 172.17.1.12,
Client mode: enabled,
Broadcast client mode: enabled,
Broadcast delay (microseconds): 10,
Server qualification: synchronized
But the system time
F2-B-1-> system time
12:00:34 (CEST)
Could some one help me with this issue.
The NTP server is a windows 2003 server
kind regards
Paul van Drongelen
NTP settings 6850,6400 and 9700 time snyc with -2 hours diff
benny
Re: NTP settings 6850,6400 and 9700 time snyc with -2 hours diff
UTC is GMT - meaning it is the base for the time. You should set your timezone matching your region.
NTP is always UTC and the switch will add the two hours to "represent" the correct time.
I think this is ok. (Just set the correct time zone if necessary)
-benny
-benny
cedric1
helllo
A I post
system daylight savings time enable
should correct issue
A I post
PaulvDronegeln
HI guys,
I have tried all you posted, still have a -2 hour diff.
System timezone GMT
System daylight saving enable
Is there something els what i could try ????
kind regards
Paul
System timezone GMT
kind regards
Paul
benny
The time reported for NTP will always be UTC. The correct timezone will set the time in "show system" to the correct one.
It would be easier for us if you would post the outputs and in addition what you expect to see.
-benny
-benny
cedric1
Good Morning,
Output exemple with Luxembourg time
251=> show system
System:
Description: 6.3.1.1070.R01 Service Release, January 30, 2009.,
Object ID: 1.3.6.1.4.1.6486.800.1.1.2.1.8.1.2,
Up Time: 183 days 1 hours 55 minutes and 1 seconds,
Contact: Alcatel-Lucent, http://alcatel-lucent.com/wps/portal/enterprise,
Services: 72,
Date & Time: TUE AUG 25 2009 10:07:45 (CEST)
Flash Space:
Primary CMM:
Available (bytes): 62812160,
Comments : None
Secondary CMM:
Comments : None
251=> show ntp client
Current time: Tue, Aug 25 2009 8:08:00.225 (UTC),
Last NTP update: Tue, Aug 25 2009 8:04:50.691 (UTC),
Server reference: 172.30.100.1,
Broadcast client mode: disabled,
Broadcast delay (microseconds): 4000,
251=> show ntp server
ERROR: Incomplete command
251=> show ntp server status
IP address = 10.30.100.1,
Host mode = client,
Peer mode = server,
Prefer = no,
Version = 4,
Key = 0,
Stratum = 4,
Minpoll = 6 (64 seconds),
Offset = 0.027 seconds,
Dispersion = 0.019 seconds
Root distance = 0.023,
Precision = -17,
Reference IP = 10.10.8.40,
Uptime count = 15778215 seconds,
Reachability = ff,
Stats reset count = 3 seconds,
Packets sent = 43257,
Packets received = 43253,
Bogus origin = 0,
Bad dispersion = 0,
251=> show system
System:
Services: 72,
Flash Space:
Primary CMM:
Comments : None
Secondary CMM:
Comments : None
Host mode = client,
Peer mode = server,
Prefer = no,
Version = 4,
Key = 0,
Stratum = 4,
Precision = -17,
Reachability = ff,
Bogus origin = 0,
Bad dispersion = 0,
antomi1
try these commands:
no ntp server 172.17.1.12
ntp server unsynchronized
ntp client enable
system timezone CET
ntp client enable
system timezone CET
