I see that someone else asked this question in another forum, but never got an answer. I would like to know if UUI is available by using the Alcatel TSAPI server API... I can not find anything in the TSAPI Server Programmers Reference Manual about UUI.
Or Alternatively is there a way I can Attach some User Data to a call? User Data as an account number or something somilar...
Kind Regards
Manie
UUI Information via TSAPI
oliveira_Arthur
krzysioD
Re: UUI Information via TSAPI
Ech, mr Arthur, i see that you should take me to a vacation to your home country.
You could attach some UUS, but it goes to 30 Bytes on private E1 link, or 16 bytes (in my country i saw 14 in one carrier) if you go with some public carrier.
For E1/PRA you must prepare proper EI value and make a check-sum (ALU never said how to make that check sum) This is the easy way: ivr with PRA card.
As for CSTA it could be done also, not that easy, but possible.
oliveira_Arthur
You re welcome. And we could make a new Alcatel Partner with clients on Poland and Brazil. PBX, IVR, recorder, CRM and Networking.
What do you think?
I ask because I can set UUI on CSTA Private Data or on my CSTA Gateway (Like TSAPI) but more simple.
What do you think?
Arthur Oliveira
Arthur Oliveira
