Voice Guide update
mbaledent
Voice Guide update
Post by mbaledent »
Hi all,
I change some prefix in my prefix plan and especially the forwarding cancellation prefix from 41 to *41.
Do you know if it's possible to update my voice guide according to this modification ?
Best Regards,
M.B.
Re: Voice Guide update
You have to use custom voice guides for this --->use generic for the ones unaffected and custom ones for the ones that you want (of course you are the one that must record them).
mbaledent
Post by mbaledent »
Thanks for your answer !
I really have to record it ? Do you mean that I must say the sentence ? Because in my voice guide CD, there are some *.wav and especially the vg00007.wav that is the guide about the forward cancellation but without the numbers at the end of the sentence... That means that I should have a tool to create custom guides ?!
Do you have more information about this kind of procedure because that's not really clear in the Alcatel documentation...
Best Regards,
M.B.
mbaledent wrote:Hi,
Best Regards,
M.B.
Then record the numbers and mix the 2 voice guides.
mbaledent
Post by mbaledent »
OK, for the creation of the sentence, i just have to "concatenate" two or tree *.wav.
But I don't know how to replace the old guide by my new one in the OXE. Because it's not wav files in the OXE...
If you know the main steps, you're welcome ;)
Best Regards,
M.B.
You need AAS (alcatel audio station) for that. Contact your vendor/provider for such operation.
mbaledent
Post by mbaledent »
Ok, thanks for this information !
M.B.
Return to “System”
