4635 VPU5 will not boot
d-mgr
Post by d-mgr »
upon start up it says...
*** WARNING !! Power Station Alarm Present ***
*** WARNING !! Board Is Not Able To Boot ***
Anyone know solution?
thanks
d-mgr
Re: 4635 VPU5 will not boot
Post by d-mgr »
also have this message.....
WARNING !! RESETTING and RESTARTING VPU5 Board, due to:
"Power Station Alarm Present"
(initiated by "user module")
d-mgr
Post by d-mgr »
Nevermind found solution.thanks
d-mgr wrote:Nevermind found solution.thanks
Would you mind share it for future reviews?
d-mgr
Post by d-mgr »
too simple :wink:
PSAL cable became disconnected :roll: :oops:
ToniMati
Post by ToniMati »
I recently had the same problem. After reviewing the psal it was OK, the problem has been on the shelf. Whit a new shelf all was OK.
slabr
Post by slabr »
Hi.
I've got the same problem. Can you please tell me what is PSAL cable and where it could be found?
On the back plane - you have power connection (filter box - with red/blue cable for 48V DC and brown PSAL cable).
PSAL signal = "-48V" during normal operation.
slabr
Post by slabr »
OK, I got it. We've moved cabinets to standard rack from original Alcatel and not connect this wire. Do I need to have the green light which is in original rack or there is only need to connect brown wire to -48V?
The best solution (if you have power supply with battery) - to install "green light" (PSAL).
In case of main power failure system will work from battery and you will have PSAL alarm when voltage will drop below 46V.
System will shutdown correctly.
You can connect -48V instead of PSAL signal - in this case you can have problem when something happen with power supply.
Return to “Voicemail (46x5)”
