Jabra/GN Telecom headset, EHS adapter, and 40x8 problems
cwsonline
Post by cwsonline »
First a little history on this: I have been testing different headsets with the IPTouch 40x8 phones to be able to make recommendations to customers. These phones use EHS (Electronic Hook Switches) so I did some research and found the appropriate EHS adapters for each model of phones.
According to Jabra/GN Telecom they have different adapters that support the ALU 40x8 phones:
http://www.jabra.com/sites/Jabra/NA-US/ ... pters.aspx
I have the Jabra LINK 14201-20 adapter with the Jabra GN9300e wireless headset.
Here is the problem I am having and I hope you can help. According to the headset manual I should set it to MSH for Alcatel desk phones. If I use this setting then the headset works fine except I get no ringing tone in the headset. According to the adapter manual I should use the DHSG setting on the headset for Alcatel phones. If I use this then I receive the ringing in the headset but no audio when answering or picking up the line. I can see on the display that I am going off/on hook but there is no audio in the head set.
I have made sure that the settings for the jack is set for headset.
Thank you
cwsonline
Re: Jabra/GN Telecom headset, EHS adapter, and 40x8 problems
Post by cwsonline »
Correction: I am using the Jabra GN9350e headset.
Did you check the interworking reports available on ABPS regarding Jabra headsets? Maybe this is a known issue.
From what I remember however this type of headset was not covered by the IWR.
FranzM
Post by FranzM »
I had same problem recently. After calling Jabra technical support, turned out that Jabra headsets recognize only 3 ringtones present on Alcatel phones: nature, standard and cold river. Also, progresive ringtone (or whatever this option is called in english) must be turned off.
