INTIP-A
yulianto
INTIP-A
Post by yulianto »
I need for your help guys.. i don't what happen my INTIPA..
my sip OXE can't call to analog...
there is my capture INTIP-A
my INTIP-A operational state=disabled
how to i can enabled this..?
─Consult/Modify: Board──────────────────────────────────────────────┐
│ Shelf Address : 0 │
│ Board Address : 26 │
│ Interface Type + INTIPA │
│ Virtual board + NO │
│ Usage State + Idle │
│ Operational State + Disabled │
│ Main/Standby State + Main (Master) │
│ Country Protocol Type + Indonesia │
│ Incidents Teleservice + YES │
│ IP Compression Daughter Board + 1 GIP6 │
│ Nb of Compressors for Gateway : 16 │
│ Nb of Compressors for IP Devices : 0 │
(1)xa000000> intipstat
Int IP informations :
Display an INTIP structure : 1
Display all INTIP structure : 2
Display INTIP MAC hash table : 3
Quit this tool : 0
Enter your choice : 2
Coupler INTIPA cr 0, cpl 26, Ghost Eqt 28868
IP Address : 10.14.201.246
Netmask : 255.255.255.0
Gateway Address : 10.14.201.1
Mac Address : 00:80:9f:53:99:77
Sign. Ip Term. Load : 0
Sign. IRC. Load : 0
Domain IP : 0
Local IP Version : IPV4
IP QoS Category : 2
Embedded Ethernet : NO
Max Comp Allowed : 16
INTER ACT LINK :
cr opp : 255
cpl opp : 255
status int : INT_HS
link_right : DOWN
used_ts : 0
bkUp access nb. : 255
bkUp Ts nb. : 255
volume_system : 1
local_volume : 0
INTIPA list inter act link : No link
thanxs for before... :D
Eliott_DUP
Re: INTIP-A
Post by Eliott_DUP »
The post is some days old but...
I guess the board is out of service. Check with config 0 26 command.
Lan cable plugged correctly?
Suggestion: Plug the console cable on front panel of INTIP and post the output.
Can you ping the board IP from the OXE prompt?
If solved, what was the problem / solution?
Return to “Boards”
