Need Command to put Event to incvisu
spynet
Post by spynet »
Hi, know enyone a command to set up an event that i can get through with incvisu?
for example:
(102)cs> put event 1101 ..Parameters.."info message"
Then I want to see the event like this:
(102)cs> incvisu
12/10/09 11:11:11 001002M|---/--/-/---|=1:1101=info message
I need the event to supervise the cpu status using the twin command for the Alarm Set to ring.
Eliott_DUP
Re: Need Command to put Event to incvisu
Post by Eliott_DUP »
Just one way for example
/DHS3bin/oneshot/mtcl/pingevt -g m -t 0 -n 1 -s "Your message" 1>/dev/null 2>/dev/null
13/10/09 20:31:11 001001M|---/--/-/---|=2:1150=external alarm : Your major msg
13/10/09 20:31:11 001001M|---/--/-/---|=3:1125=external alarm : Your minor msg
13/10/09 20:31:11 001001M|---/--/-/---|=4:1101=external alarm : Your warning msg
13/10/09 20:31:11 001001M|---/--/-/---|=1:1175=external alarm : Your critical msg
(101)OXE> /DHS3bin/oneshot/mtcl/pingevt  -h
pingevt [-g [wmMC]] [-t tempo] [-n -1..n] [-s "string"]
        -g(ravite) w(arning) m(inor) M(ajor) C(ritical)
        -t delay in millisec between emission
        -n -1 : infinite emission, 0..n nb of emission
        -s "string" : default text is 'pingevt seq #seq'
                      string max length is 19
   warning  is incident id 1101
   minor    is incident id 1125
   Major    is incident id 1150
   Critical is incident id 1175
Return to “Usefull commands”
