ars configuration
penny
ars configuration
Post by penny »
we did interconnectity with omnipcx enterprise with seimens pabx over qsig
protocol and can reach seimens users by dialing trunk group overlapping prefix +
seimens pabx extension number.
but customer wanted to dial seimens users directly with out dialing trunk group
overlapping prefix.
it is possible through ars? if so can please give us configuration steps.
Re: ars configuration
Use speed numbers:
1
dialed nb: *401 (*40 ARS seizure)
alex
Post by alex »
tot3nkopf wrote:Use speed numbers:
1
:shock:
It is QSIG. Why not just use routing numbers?
1
:shock:
My bad :lol: :lol: :lol: . Didn't pay enough attention. You are right of course.
Suresh
Post by Suresh »
you can use "open routing number" prefix
Nazir
Post by Nazir »
The same problem, I have faced on Huawei pbx that Huawei user wants to dial outward via Omni pcx exchange on Qsig protocol , please give me clue regarding dailing path .
hi
oxe should understand what's coming from huawei , if huawei users would like to dial to external network throuhg oxe ,huaweri should send request about that using an understood number for that puropose
exemple
if on oxe external prefix (ars or not) is 0 ? HUAWEI USER should send 0(the requested service) +called number so ur huawei pabx should route any number starting by 0 toward oxe
2nd thing , you should check the connecetion cos between the qsig and the external trunk group at oxe levl ,
Return to “MAIN”
