I've got an issue bringing an OC48 link up between two 7750 equipped with iom2-20g + m2-oc48-sfp.
The config of each port is as follows:
A:7750_A>config>port# info
sonet-sdh
hold-time up 50
path
no shutdown
exit
exit
no shutdown
A:7750_A>config>port# show port 10/1/1
SONET/SDH Interface
Description :
Interface : 10/1/1 Speed : oc48
Admin Status : up Oper Status : up
Physical Link : Yes Loopback Mode : none
Single Fiber Mode : No
APS Group : none APS Role : none
Clock Source : loop Framing : sonet
Last State Change : 09/09/2009 13:35:19 Port IfIndex : 337674240
Last Cleared Time : 09/09/2009 19:41:34
J0 String : 0x01 Section Trace Mode : byte
Rx S1 Byte : 0x0f Rx K1/K2 Byte : 0x00/0x00
Rx J0 String (Hex) : 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Cfg Alarm : loc lrdi lb2er-sf slof slos
Alarm Status :
Hold time up : 5000 milliseconds
Hold time down : 0 milliseconds
Transceiver Data
Transceiver Type : SFP
Model Number : 3HE00046AAAA03 ALA IPUIARBDABB
TX Laser Wavelength: 1310 nm Diag Capable : yes
Connector Code : LC Vendor OUI : 00:90:65
Manufacture date : 2008/12/14 Media : SONET/SDH
Serial Number : PERXXXX
Part Number : FTRJ1421P1BCL-A5
Optical Compliance : OC48-IR-1 GIGE-LX
Link Length support: 20km for SMF;
A:7750_A>config>port# show port 10/1/1.sts48
Path Info
Description : STS48
Admin Status : up Oper Status : down
Mode : network CRC : crc32
Encap Type : ppp-auto Configured MTU : 9208
Operational MTU : 9208 Operational MRU : 9206
Last State Change : 09/09/2009 19:33:44 Path IfIndex : 874545153
Scramble : false
Accounting Policy : None Collect-Stats : Disabled
Net. Egress Que Pol: default Load-balance-algo : default
Egr. Sched. Pol : n/a
Signal Label : 0xcf Rx Signal Label : 0xcf
Trace String : Alcatel 7750 SR
Rx Trace String : Alcatel 7750 SR
Some of you might tell me "there's a loop somewhere" but it has already been checked; none found,
software or hardware.
Thanks in advance !
