New 9 series (4039) handset freezing
You found one ?
You know about one ?
Share it !
spot the ?
Post by spot the ? »
Hello, Has anyone come across the new 4039 (9 series) handsets freezing. I've had odd occurancies of it mainly 4039's resetting the phone is the only to get it working again. I've had it happen on 6.2 OXE and 4.1 15.005 OXO.
I've checked the BPWS i cant find any TC's related to it.
Any feed back would be great.
thanks
spot the ?
4039 Terminal Version is 2.11.02
There is a patch for this (I believe you are using release 6.1 ?)
it's patch 17c
Vnbadiger
Post by Vnbadiger »
Thanks frank!!
even I faced the same few days ago.But this happened on one particular board so reset that card. I have 4039 set connected to other UA board but did not faced the same problem.
I wonder why!!
One silly question to you spot the.
did it happened to all the 4039 phones or just few phones.
There is a patch for this in 7.0 I think, and for sure in 7.1
axel_h
Post by axel_h »
If you find some UA sets that just quit ringing (incoming calls are only displayed): there are a couple of them around produced between late 2004 and end of 2006 that have some defective devices installed. They use to stop to activate the speaker to send the ringing tone after some months. Alcatel told me these setts are being repaired for free even if they are out of warranty period.
Wibble_2007
Re: New 9 series (4039) handset freezing
Post by Wibble_2007 »
Is the issue not with the ringer but the actual phone freezing? If it is the phone freezing, then you need to upgrade your software. Also if you find this issue with 4019 sets as well, there is a specific binary fix for this. The 4019 sets freezing was because of the RoHS compliant laws passed over. This caused the lead free component to be removed, thus causing a binary issue and kept resetting the sets.
Return to “Bugs & Security issues”
