Busy camp on not working for Analogue phones on Rel 9
Pendix
Post by Pendix »
If I set Busy Camp on = false in an Analogue users Dynamic state user, I get an Error message: “Analogue set is in idle state”.� can set this if I lift the receiver, however when I go back in it reverts back to True.
Very strange!!
Has any one got a clue???
Re: Busy camp on not working for Analogue phones on Rel 9
What release exactly in your PBX? Whas problem with changing in dynamic state for analog set in patch before 10 (as I remember).
Pendix
Post by Pendix »
I am using h1301.36 however this is the same in patch 35 as well.
Yes, I check and we have the same problem - again request to ALU :(
Eliott_DUP
Post by Eliott_DUP »
That is the normal behavior for analog sets since year 2006.
This is not a bug , but a modification in the software due to XTSce62328.
Since R5.1.2 e2.504.1.aj, R6.1.1 f2.502.23, R6.2 f3.301.28 and R7.0 f4.401.20
Before :
If we disable the "busy camp on" on a analog set by dynamic state user in the MGR, and if the set is onhook the function "busy camp on" is not taken into account. However the boolean busy camp on is NO.
If on the other hand, the set is in conversation at the time of disabling, the function "busy camp on" is disabled.
After:
Restriction of management of camp-on feature for analog sets when it is idle.
If you try to manage the camp-on feature for the analog set when set is in idle, error message should be displayed.
Manage the camp-on feature when the set is in conversation, modification should be accepted in this case.
Warning: Change Camp on for analog sets works for just 1 call - see R3.2 Bible Page 531 Chapter 2.1.7.
Ok, thanks Eliott
Return to “GENERAL”
