How to prioritize certain incoming number within CCD
Those are some home made documentations that people made.
If you wrote a documentation that you would like to see here, please contact the administrator of this site ! We would love to hear from you !
Let's say that you have a call center, using CCD
Let's say that the customer tell you "if my field engineers call for tech support, I want them to be #1 in the queue"
How would you do that ?
You would follow what I wrote in this document :)
Enjoy !
DrImpresion
Re: How to prioritize certain incoming number within CCD
Post by DrImpresion »
Thanks!!!
Tan Phu
Post by Tan Phu »
Thanks for your docs. It's really helpful to me
alf
Post by alf »
is there a maximum number of calling numbers in acr database?
We get an empty error message when we adding the 21 entry.
thanks a lot
Alf
There are limits, if you want more you can install the acr server on a pc
alf
Post by alf »
we have checked this with Alcatel.
You can define 3000 numbers in Applications -> CCD -> Skill -> Customer parameters, so we need no ACR server at this time.
We cant edited the numbers in CCS because there was a issue in this version or installation we used.
After updating the CCS more than 21 entries can be added and edited.
Alf
lhjr_mhc
Post by lhjr_mhc »
I go test. Thank you
Return to “"Home Made" documentations”
