Providing PSTN services through other location on VoIP
reza666
Post by reza666 »
Hi guys,
how is possible to provide a location with no local PSTN Provider connection to get out through HQ trough VoIP?
Here is the situation:
I am working in location A, our PBX is connected to local PSTN provider for connecting to outside calls
For dialing out I just pickup the phone and dial 9 follwo-up with telefone number
I have a VoIP location B with seperated PBX with no local PSTN provider
Location A and B are conneted through IP Trunk to each other
How can I provide location B the same as in location A for dialing out through location A by dialing 9 follwo-up with telefone number?
Thx
Reza
knightr1der
Re: Providing PSTN services through other location on VoIP
Post by knightr1der »
is it a voip trunk group between the 2 locations?
Are the 2 networked properly with ABC Internode link?
reza666
Post by reza666 »
is it a voip trunk group between the 2 locations? Yes
Are the 2 networked properly with ABC Internode link? No
Of course you can: basic break in (use translation to speed dialing pointing to IP of the remote site), break out configuration (dial - fromremote site - IP TG prefix + ARS prefix of the remote site + PSTN number).
knightr1der
I think you will also need to ensure Connection Category 5 is allowed to connect to category 5 and make sure PNC of IP trunk group allowed for access areas.
