Reset a voicemail password using mgr
secnewton
Does anyone know how to reset a user voicemail password using mgr?
Thanks!
Thanks!
secnewton
- frank
How does your system look like ?
Is it a 4400 http://www.comnetpl.cz/img/sluzby/ustredny/4400.jpg
or does it look like this http://www.sybord.fr/activ/images/Alcatel_OXE.jpg ?
The only way to change the voicemail password in a 4400, which is a 4635 type of Voicemail is via a termial connected directly onto the Voicemail off the back plane or you can connect the voicemail cable to a RMA and you can access via dial up. There is no way to cahne a password via mgr to a 4635 voicemail system
secnewton
