Route incoming call to specified extension when OXE off?
doublevand981
Post by doublevand981 »
Hi all.
Any one know how to set up for incoming call route to specificed extension port whe OXE or OXO turn off ( lost power supply)
pls share with me
thanks
ccube
Re: Route incoming call to specified extension when OXE off?
Post by ccube »
Hi doublevand981,
Please find under OXE Documentation\System Documentation\Public Networks\Power Cut Through Facility the procedure you are looking for. This works only for CommonHW (APA) boards.
ccube
doublevand981
thanks so much
Spriggan43
Post by Spriggan43 »
The Documentation is not clear on if it’s only the first port or all ports on the APA card that can change over on a power outage.
yoursfather
Post by yoursfather »
Only the 1st port
Return to “System”
