OHL Driver and Aplication
efreitas
Post by efreitas »
I use the OHL (ticketcoletor.xml) for comunication with my aplication (software tarifação).
Is there any version OHL driver that give me permition management one or more OXO?
I just need that 01 OHL collecting tickets 1 or more OXO
It is possible to develop my own application to eliminate the OHL?
thanks.
MR_PT1
Re: OHL Driver and Aplication
Post by MR_PT1 »
efreitas wrote:Hi,
thanks.
It seems you can open two or more OHL session each one connecting an OXO... But I think only 01 OHL connecting more OXO dont't work because you have just one field to insert the address... I used OHL many years ago, maybe it was increased... :?
enio.eltz
Post by enio.eltz »
Hi efreitas
OHL can be used only with one oxo. If you need to collect two or more oxo you need to run two or more OHL in different computers. Until now there isn't another way due to you can only put one IP address on the OHL.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
MR_PT1
Post by MR_PT1 »
enio.eltz wrote:Hi efreitas
Best regards.
Maybe virtual machines...
enio.eltz
Post by enio.eltz »
Hi there
Yes, maybe virtual machines it works.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
Return to “Applications”
