Voice mail-4635 installation
This forum is for misc discussions that have nothing to do with Alcatel-Lucent.
Suresh
Post by Suresh »
Dear All,
I need your valuable inputs for the voice mail installation, this is a new installation and during switching on the vpu6 board board seize to boot as per below:-
Alcatel 4635Prom Resident Test Demon, Integrated Version
Board Self-Test Status:CPU Test........................................... PASSED
Console Test....................................... PASSED
Data/Stack RAM Test................................ PASSED
MTA Support ....................................... ENABLED
XOFF/XON Timeout .................................. ENABLED
Scrubbing all "known" DRAM memory ..... (00000000-04000000)
C67 test nb# 0 enabled
C67 test nb# 1 enabled
C67 test nb# 2 enabled
C67 test nb# 3 enabled
C67 test nb# 4 enabled
C67 test nb# 5 enabled
C67 test nb# 6 enabled
C67 test nb# 7 enabled
Timer Test......................................... PASSED
Copyright 1994-2006 Alcatel
System CPU PROM Version: e108VPU5 (Oct 31, 2006 15:41:55)
Board Type is: VPU5
VP_DIAG: RUN *
Display (But NOT Execute) Self-Test Status......... (00) STARTED PASSED
DRAM Walking 1s DWORD Test......................... (33) STARTED * * * * * * * * * * * * * * * * * * * * PASSED
DRAM 3Par DWORD Test Executed From DRAM............ (7D) STARTED * * * * * *** * * * * PASSED
Write/Verify Misc Registers........................ (2F) STARTED PASSED
Ethernet Test...................................... (74) STARTED PASSED
IPoC Controller Test............................... (4A) STARTED PASSED
IDE Disk Configuration............................. (50) STARTED
X.
IDE Disk Configuration............................. (50) PASSED
IDE Disk Drive Diagnostic.......................... (4D) STARTED PASSED
IDE Disk Read Test................................. (4E) STARTED PASSED
Crystal-1 Chip Test................................ (56) STARTED PASSED
C67 DSP Functional Test............................ (20) STARTED * * * * * * * * * * * * * * * * * * * * * * * PASSED
Watch Dog Timer.................................... (5F) STARTED PASSED
Please select from the following:
B Boot the System
^DB Boot the System (clear autoboot, set SRAM=0xFF)
^DD Run Diagnostics Interactively
Selection-> D
B Boot the System
Selection->
No response...
- Beginning OS BOOT process
[4635J] Initial Program Load Phase 1 (IPL1) Begins
PPIIPPLL VVeerrssiioonn :: 00222266
BBooaarrdd TTyyppee :: VVPPUU55
SSttoorraaggee TTyyppee :: IIDDEE
SSyysstteemm TTyyppee :: AA44663355VV
LLooookkiinngg ffoorr CCoommbboo FFiillee SSyysstteemm......
i have installed such boards earlier without any issue, but unable to know the reason for this behavior.
appreciate your feedback
Suresh
knightr1der
Re: Voice mail-4635 installation
Post by knightr1der »
and what might be the reason you have posted your message in this completely wrong category and topic?
Maybe he found funny the message :)
Return to “Outside World”
