4039 Agent set
Alcatel_exp
4039 Agent set
Post by Alcatel_exp »
I have installed 4039 agent set. I have a problem with the call tag display.
I have configured the display to be caller id and pilot name.
The display for the caller id is only 6 characters, I tried to put the pilot name 3 characters and the same. it is always 6 characters. I replace the agent with 4035 sets and it is working fine. is there any specific configuration for 4039 to display more than 6 charatcters for the caller id.
hi i have been searching for documentation about usong the 4039 as an agent set and couldn't find any, do you have any info about it?
This is possible from release 7.
yes i know that, but configuration is as simple as declare the set as proacd? or do i have to configure the ccd button on the sets?
iourid
Post by iourid »
Configure 4039 as ProCCD set and 4068 as an agent/supervisor. Logon softkey will be on menu page key 8 by default. I soon as you logged in, main page becomes CC, where you have your usual CCD softkeys.
iourid
Post by iourid »
Forgot to say that CCD docs come separately from System docs and are available on BPWS.
Do you have the name of the doc? I have searched on all BPWS for any info of this and nothing.
iourid
Post by iourid »
Sorry for late reply.
You go to BPWS->Technical knowledge base->Click on "Select you product", select OmniTouch Contact Center Standard Edition(or Premium) -> Click Download.
do yo need a special password for the Technical Knowdlegde Base??
iourid
Post by iourid »
Not that I know.
Return to “CCD / CCS / CCIVR”
