analog sets not working with ABC-F
gundam
Post by gundam »
Hi All,
Any1 run into this issue before:
2 PCX nodes (e25041h) connected together via ABC-F (T1 CCS)
Outside Calls entered from node 1 and is routed to node 2.
Calls to digital phone go to node 2 without issue, but calls to any Analog set drops immediate after the call setup.
From t3 trace I see the call set does go across the ABC-F.
For now, to get around the problem I setup a Ghost Z and have it immediate forward to the analog set.
Any idea what is wrong?
Incoming trunk group present on node 1 and node 2. Do you have the same NPD decleared in TG/NPD selector on both sides?
gundam
Post by gundam »
The issue was finally resolved by doing the following:
under /system
Ignore ISDN Fault In Mandatory EI
Ignore ISDN Cause Invalid Content
I change these from NO to Yes.
Return to “ON SITE TROUBLES”
