Answer machine not working correctly on SLI board
John.Daly
Post by John.Daly »
I have a strange issue whereby you have an analogue phone plugged directly into the port of an OXE, common hardware. Phone the extension and this works fine. If I take an answer machine (for example a BT response 75 unit) and plug it in it does not answer the call. If I plug an analogue phone off the back of it, the analogue phone rings but when you lift the reciever it does not answer the call.
If you plug just the analogue phone in it answers when you lift the reciever. Plug the answer machine into a direct exchange line and the answerphone works perfectly fine with or without an analogue phone on it.
I then took the common hardware and plugged into an OXO and the answer machine does not answer the call, but I can pick up the call from the analogue set plugged into the answerphone. Interesting.
Anyone have any ideas? Any frequency settings?
MMhh.. Interesting.. Unfortunatly, I do not have any answering machine to make the test here... Why are you trying to do that ? I'm curious.. How come you do not use the embeded voicemail ?
John.Daly
Post by John.Daly »
Because the customer has their wallet shut and don't want to pay for voicemail. They have 18 remote shelves and do not want voicemail at all. It's sad I know. They want to have an answer machine at each site for their night services only.
Seriously, I have no clue why an answering machine would not work on a SLI board. One of my customer put answering machines on crystal Z boards, and it works perfectly
I also have a customer who uses answering machines as VM, not sure how he made it but can ask.
mirceahuh
Post by mirceahuh »
I am just curious, when you tested the answering machine, the call was internal or external? Because the ring cadence is different for internal and external calls. One is shorter, and maybe this is the reason why is not working.
I had this issue with a fax machine and had to modify the ring tone.
Regards.
John.Daly
Post by John.Daly »
I tested both Internal and external calls. Both did the same thing. It is very interesting as to why this is occuring. I'm going to build me an old 4200 and see if it does it on this as well. Will let you all know.
sadim
Post by sadim »
I think i already had this problem on the past. As far i can remeber, the problem is related with the ringing voltage. Measure the ringing voltage on a SLI and on a crystal Z board, and in case the voltage diference is considerable, ask to the answer machine support what should be the expected ringing voltage.
As far as i know the OXE ringing values are complaint with the norm’s, and there is no way to increase it (in case of SLI), anyway if it is the case you can open a tickt at Alcatel to check this possibility.
Regards.
John.Daly
Post by John.Daly »
Will do. Thanks. I will try and measure the voltage of the SLI. Thanks
dj2000
Post by dj2000 »
Anybody has found a solution for this issue? we have a similar problem with an elevator intercom, I've checked the voltage in SLIs and it is 28V, the intercom needs 48V to operate correctly, I checked the voltage in a Z24 and it is 48V, as it should be....
The ring voltage is correct, 96-100V, we have rechecked all the parameters in the SLI, but didn't found a way to change the voltage. Tomorrow I'll try to find out if there is any hidden jumper on the board... :roll:
If somebody has new information, please share it! Thanks in advance.
Return to “Users”
